speaker buzzing
kyle carpenter
one of my speakers is buzzing when i turn up the volume.
what do i do?
what do i do?
Post edited by kyle carpenter on
kyle,
Welcome to the forum.
Simple, turn it down.....;)
Help us out here with somemore info. What kind of speakers?What are you using for power? Is it a tweeter or driver or all of them that buzz? Does it do it with all sources? Etc.......
F1Political Correctness'.........defined
President of Club Polk -
what do i do?
Dude, Im guessing its your tweeter. Do you use a Yamaha Receiver? If so, it could majorly be your amp! I had a problem with buzzing from my Tweeters and when I upgraded to a better, different brand receiver it went away.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Tweeters don't typically 'buzz', usually a 'buzz' is a rubbing voicecoil on a midbass/woof. Like F1 said, check your sources, and also swap l/r see if the problem follows the speaker.
Cheers,
RoosterCheck your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
start by swapping the speaker wires in the back of your amp/receiver that will tell you if the problem is the amp or the speakers. if it proves to be the speakers, try to listen to the individual drivers as you play something that you know reveals the problem. That means up close, so don't turn the music up too high. Once you've isolated the failing component, call and get a replacement. You can do the work yourself or pay $55/hr to a local tech to do it.B EZ
