Polk's Box builder
GLIDN
GLIDN Posts: 1
edited October 2009 in Car Subwoofer Talk
Does anyone know what happened to this or have the link to this?
they use to give you recommended Sealed,ported and bandpass box specs for everyong of there subs.
It even included the cut out specs and graph statistics too.
I'm trying to figure out what the sealed box specs are for the Polk DB1040DB.
Also hoping running a PA400.1 @ 400Wrms @ 1ohm should be sufficient in terms of power otherwise i'll go over kill and power them with a PA1200.1.
Or upgrade to Polk momo 10"DVC but i know they need more then their minimum power. generally almost 1/3 more then minimum required power.
Post edited by GLIDN on
