Gauge size ?
RSTERN
What gauge wire should i use to run 2 amps, a pa 1200.1 and a rockford fosgate 750x. The run would be about 20 feet. I was going to run one wire back a then split it. Would 2 ga. be enough? Thanks
Rob
Rob
mains: rt16
center: csi40
surrounds:fx 1000
sub: SVS 20-39pc+
center: csi40
surrounds:fx 1000
sub: SVS 20-39pc+
Post edited by RSTERN on
1/0 gaugepolkaudio sound quality competitor since 2005
2 ga. would b enough. no?Polk MM6501 kick panels, Eclipse cd7200mkll and SW9122 Bomb Box, Cadence A4, A7, CAP5, JL8W3V3
1600 watts?? No, 2 gauge wouldnt be enough. You could maybe scrape by with 2 if you werent running a lot of bass heavy music, used the sub amp at 4 ohms and such but why chance it. Do it right.polkaudio sound quality competitor since 2005
+1 for 1/0 and you won't regret spending a little extra in the first place.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
ok thanx mac. can i ask..what if 2ohms(800w) plus RF 750x(lets say 300w)=1100wrms. would u still advise 0/1?? pretty interested since i use 4ga. on similar setup..Polk MM6501 kick panels, Eclipse cd7200mkll and SW9122 Bomb Box, Cadence A4, A7, CAP5, JL8W3V3
I think the idea is to go a little over so there is no doubt there is enough power for everything. That way if i upgrade stuff, power and ground will not have to be. Thanks guys.
Robmains: rt16
center: csi40
surrounds:fx 1000
sub: SVS 20-39pc+
