SDA-1C XO upgrade - 750pF cap questions
thsmith
thsmith Posts: 6,082
edited October 2009 in Vintage Speakers
I have been reading everything I can find on upgrading my 1C XO. Mainly these 3 threads.
https://shop.polkaudio.com/forums/showthread.php?t=47379
http://www.polkaudio.com/forums/showthread.php?t=57467&highlight=SDA+crossover
http://www.polkaudio.com/forums/showthread.php?t=40330&highlight=SDA+crossover
I am confused about what to do with the 750pF cap. Seems most people bypass it.
Why ?
Thanks,
Tracy
  • Face
    Face Posts: 14,340
    edited July 2009
    It was done to improve the SQ of the caps they were bypassing. Capacitor technology has come a long way since then and they are no longer needed. Plus bypassing can cause artifacts and smearing, you should use a single cap(value) whenever possible.
  • NJPOLKER
    NJPOLKER Posts: 3,475
    edited July 2009
    Its a bypass cap which is not needed with higher performing capacitors. Majority of people also feel they give a funky/fake/colored sound or something like that.
  • NJPOLKER
    edited July 2009
    Face, your faster than me and more knowledgeable too!!
  • thsmith
    edited July 2009
    Thanks Face, So all I need is the 12uF HQ film cap and remove the 750pF cap ?
  • Face
    Face Posts: 14,340
    edited July 2009
    Correct.
  • Conradicles
    Conradicles Posts: 6,435
    edited September 2009
    Silly question...but when you guys say "bypass"...that means just totally remove this little 750pf and NOT replace with a jumper wire correct?
    Doing mine tomorrow and just trying to get all the facts. Thanks!
  • ben62670
    ben62670 Posts: 15,969
    Yes remove, and place nothing in the hole the bypass cap came out of.
    Ben.
    Ben
  • kawizx9r
    kawizx9r Posts: 5,150
    Oh whoa, over here Ben's been helping me alot in choosing my caps for my upgrade as well. There's a 750pF in there?...it wasn't in the SDA parts list sticky thread. Glad I read this post, thanks guys!
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • Systems
    Systems Posts: 14,872
    Definately no to the wire jumper.Adding one would effectively remove the main cap(12uf)from the signal path,thus the tweets would be receiving the full frequency range.The result will be tweeter failure not to mention horrible SQ before they expire.
    Testing
    Testing
    Testing
  • thsmith
    edited October 2009
    Keep us posted, I am ordering my parts today.
