Fixing an Adcom GFA 555
pablo_rodz
Hi all,
I just got a used Adcom GFA 555, it looks different to all the 555's I've seen, so I think it's kind of old.
The amp was cheap because the right channel RCA Jack is broken. I thought it was going to be an easy and cheap fix, but the two (2) RCA inputs are in one plastic unit. I need help finding a new RCA jack "thingy". At least the amp powers up and seems to work.
Below are pictures of the amp opened up and the RCA jack plastic unit/thingy
It looks clean, the caps are not swollen or leaking everything looks great.
The broken Right Channel RCA Jack
The back of the RCA jacks
The plastic RCA jack unit
This is where the RCA's are soldered to the board
HT:
Projector - JVC HD100, 100" Fixed Screen, A/V Receiver - Pioneer Elite VSX-92TXH, Power Conditioner - Panamax M5300-EX, BluRay - Sony PS3, (2) ADCOM GFA 555 Bridged, Speakers - LSi 15, LSi C, LSi FX, Sub - 12" M&K VX-1250.
Living Room:
Schiit Saga, Parasound HCA-600, OPPO BDP-103D, LSi7
Living Room:
Post edited by pablo_rodz on
Don't most older GFA-555s just have TWO large Blue 30kmfs CAPS not four? So are those new mods to that unit?
I did check PE, but the RCA jacks they have are for chassis mount, I need the plastic RCA pad (L+R in one). If I cannot find it I'll have to rig-up somethingHT:
Living Room:
Schiit Saga, Parasound HCA-600, OPPO BDP-103D, LSi7 -
cnh
I have no Idea, the guy that sold it to me had no info. on it, he even asked what I wanted it for :eek:, that he had no idea why will some one need one...:rolleyes:HT:
Living Room:
I may have been wrong about those caps....perhaps it is 4 X 15K. And 16 small caps.
See this link for a photo to compare with yours.
http://www.polkaudio.com/forums/attachment.php?attachmentid=16755&d=1148038682
cnh
that is correct it has (Capacitor Technologies) 4 x 15000 MFD 80 WVDC
and 16 Toshiba small caps.
Does someone knows what does this mean on the Toroidal Transformer 01124 708 VA 11 85 ???HT:
Living Room:
Anyone??
Does anyone know where I can find a dual RCA jack?HT:
Living Room:
you might try and contact this guy...
http://www.alibaba.com/product-gs/50034743/RCA_Jack.html
or better yet save up some cash and send it to these guys...
http://www.musicaldesign.com/adcom.htm
or at least call them and see if you can source that part somewhere...
DavidI like to listen, tinker, listen and repeat. -
Pedro....try:
www.jameco.com
they're very likely to have it...u may have to do extensive searching or call them tho.
Good luck....at worst you can rig one im sure.Cool stuff: Adcom GFA-555, GFP-710, Oppo BDP-83, Monitor 10's w/RDO198s, rebuilt and modded XO: Sonicap/Mundorf topside, Daytons Low.
Benq W5000
"Leaning back like a maxwell tape commercial listening to pure polk bliss" -
David
Yikes that would be quite a bit of cash:(
I wonder If I could do some of that myself:eek:HT:
Living Room:
+1. I'm sure Dr. Polkenstein can hook you up.I refuse to argue with idiots, because people can't tell the DIFFERENCE!
So Ben or Dr. Polkestein are the guys to find??
But I would like to learn how to do it....HT:
Living Room:
Hi all!
I just ordered a pair of gold plated RCA Jacks to fix the amp. I couldn't hold my self and decided to hook-up my new Atrium 45 to the amp to see if it works....
Well the right channel works, music plays fine, but the left channel has a Humm/ buzzing sound. The humm is even present when I remove the Interconnect (cable).
Does anyone have an idea of what could be causing it?HT:
Living Room:
I tried searching by his name but I got no results...HT:
Living Room:
pablo_rodz wrote: »
Does someone knows what does this mean on the Toroidal Transformer 01124 708 VA 11 85 ???Testing
Testing
Testing -
pablo_rodz wrote: »
Does anyone have an idea of what could be causing it?Testing
Testing
Testing -
Coupling capacitor maybe or you still have a open signal or cracked ground on that jack? Since you have obvious external damage, I'd focus on that first.
Coupling caps COULD be something like those round yellow caps that I think I see four of in one of those pictures. Somebody with experience on that amp might be able to send you right to the correct parts in there. Just know what your doing before you poke around in there...those big caps mean business and may hold a charge long after it's off!!
CoolJazzA so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements." -
I'm sure this is who Lasareath is referring to...
http://www.polkaudio.com/forums/member.php?u=76154
Ben knows about Adcoms, in fact he's who I bought mine from (GFA555).
He's also a pretty good guy, but that's just IMHOSo, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
http://audiomilitia.proboards.com/ -
Ben is great at exactly this kind of thing among a whole host of others. And offers to help anyone out there who needs it. He knows his stuff.
When I first got my Adcom, he told me to drop it by and he'd take a look at my caps, etc, if I were down his way. I have a friend in Atlanta and occasionally get down there. I will certainly lug the Adcom down on my next trip.
Drop Ben a line and get an estimate...and check out your shipping options.
I don't believe those had coupling caps
I PM'd Ben....
Thanks...
Also, I haven't replaced the RCA jacks, I just ordered them today. How do I discharge the caps, before shocking myself???
Thanks again!HT:
Living Room:
dudeinaroom wrote: »I don't believe those had coupling capspablo_rodz wrote: »How do I discharge the caps, before shocking myself???
Thanks again!Testing
Testing
Testing -
where did u find the part btw?? should this ever so sucky situation arrive....I'd want to know.......Cool stuff: Adcom GFA-555, GFP-710, Oppo BDP-83, Monitor 10's w/RDO198s, rebuilt and modded XO: Sonicap/Mundorf topside, Daytons Low.
Benq W5000
RandyWilliamson wrote: »where did u find the part btw?? should this ever so sucky situation arrive....I'd want to know.......
I havent found the part, I'm going to try to "rig-it up".HT:
Living Room:
Well I got the RCA Jacks, and solder iron today.... Can't wait for the weekend to "fix" the amp.HT:
Living Room:
pablo_rodz wrote: »Can't wait for the weekend to "fix" the amp.
Well that didn't work!
The HUMM is still present, and louder.
I tried PMing Ben, but his PM's are maxed out!HT:
Living Room:
Not to jack this thread,, but WHERE IS BEN???...Anyone Know?Im a little worried as I havent seen any posts lately and thats not like him.SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
Ben is in Conneticut visiting his mom. -
That amp has been modded quite a bit. You are going to need new jacks. I would just use some nice after market types.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Welcome back.I refuse to argue with idiots, because people can't tell the DIFFERENCE!
