Help w/ PSW650
MAP1911
I have a Polk PSW650 in my TH. It just stopped working. The green light goes on but I get NO bass out of the sub.
I used it on Monday with no problems.
Any suggestions or help would be appreciated,
TIA
Mike
TIA
Mike
Post edited by MAP1911 on
Check for a blown fuse - probably around 3 or 4 amps.
Check your AVR for a spontaneous settings change (i.e., sub is now set to no/off).
Check for a loose or disconnected sub cable."What we do in life echoes in eternity"
SVS -
Dr. Spec,
Thanks for the quick reply. I checked 2 & 3 and they are OK.
I looked in the Instructional Manual that came with the sub and there is no mention of a fuse. Can you provide more info?
Thanks again,
Mike -
First try a speaker level connection to the sub from the mains output. Set the mains to large and the sub to off/no and connect one of the mains leads to the sub and see what happens.
Re: the fuse - some plate amps have a fuse - I don't know about the 650 in particular."What we do in life echoes in eternity"
SVS -
I spoke w/ Polk customer service today (3/3/03). They talked me through trouble shooting the problem. It came out that one (1) of the drivers was not working. So, off to CA for a replacement.
Dr. Spec, thank you for your assistance.
Mike
