orion specs
GTFreak
GTFreak Posts: 25
edited April 2009 in Car Subwoofer Talk
can anyone tell me what would be a good box size for a orion hcca 12.4. i'll throw up some specs. thx for the help guys.
Subwoofer Size : 12"
Design : DUAL 4-Ohms
Power Handling (RMS) : 2000 Watts
Power Handling (MAX) : 4000 Watts
Sensitivity : 85dB
Frequency Response : 24Hz~250Hz
Impedance : 4-Ohms
Mounting Depth : 10.276"
Approximate Weight : 76.9 LBS
materials
Paper Dust Cap - Moisture and UV Resistant
Tall, Wide, Balanced, NBR Foam (High Density Expanded Polyester Foam)
Tri-Radius Symmetrical Edge Design
Paper Cone - Moisture and UV Resistant
Custom Cast Aluminum Frame
Spider Ring Attachment Screws (8 Hex Screws)
Aluminum 4" Voice Coil Former
Voice Coil Cooling System
11mm Steel Front/Back Plate - Pole Piece T Yoke Assembly
Large 3 Stack Ceramic Magnets (445 oz)
1.25" Vent - Aluminum Heat Sinking
Voice Coil Gap Vents
Cast Aluminum Rear Pole Piece Heat Sink with Fins and Vent Holes
High Temperature (Polyester Amide Resin Coated)
Bottom Interlaced Conex Spider with Stitched and Looped Tinsel Leads Attached
Spider Spacer and Spider Mounting Ring Assembly
Surround Clamp Ring
