RTIA9...which speaker wire
kornkid2g1kornkid2g1 Posts: 3
hello all in the audio world. another common question for all of you. i have an onkyo txsr804 i'm using as a pre amp and a 300 w at 8ohm power amp to power my two polk rtia9s. i still have old monster 18 guage stuff from my old set up. looking to get a better sound with my new amp. i'm willing to spend around 100 dollars or so. any suggestions... don't care about in wall rating. any brand suggestion. audio quest, blue jeans, signal cable. i know alot of you despise Monster but i can get about 50-60 percent off any of their cables... would you take advantage of it? or go with a different brand. thanks for all the help
Post edited by kornkid2g1 on
  • obieoneobieone Posts: 5,056
    edited January 2009
    Welcome to the forum. I'd recommend 14 gauge. People dislike Monster for a variety of reasons, mostly, for the way they treat competitors, and other businesses in general.
  • leroyjr1leroyjr1 Posts: 8,799
    edited January 2009
    Welcome to the forum!!!! Look into Audioquest type4 wires and Signal cable wires both are great and around $100.
  • george danielgeorge daniel Posts: 11,944
    edited January 2009
    Signal cable,, mention to Frank that you are a CP member and IIRC, you'll receive a 5% discount. Good luck. :)
  • Eric WEric W Polk Customer Service Posts: 556
    edited January 2009
    How long is the run between speakers and amp?
    -Eric
    -Polk Audio
  • AlesamuAlesamu Posts: 1
    HI I have the same problem
    distance betw amp/speak 8 mts
  • mrlorenmrloren Posts: 1,477
    edited August 9
    I find Monster cable to be overhyped overpriced entry level speaker wire.
    Depending on your budget of $100 and how long of runs you will be doing.
    Look for Audioquest Type 4, I got lucky and picked up 3, 10' for $50 I just had to replace the ends on two of them. They also make a 14/2 that goes for $1.04 a foot and 14/4 which is close to $2 a foot
    Doug's Furez is a good speaker wire https://douglasconnection.com/Raw-Speaker-Cable_c33.htm
    last on my list would be monoprice 12awg wire.
    For banana's I like these Audioquest ones https://www.amazon.com/gp/product/B011AAU5UI/ref=ox_sc_sfl_title_18?ie=UTF8&psc=1&smid=A29BZ1S30D0GLZ they also come in silver (which I use)
    please remember that the cable is one thing but if it's not terminated correctly it will be bad.
    Family Room:
    Samsung UN60H,
    Denon AVR-X4400H, Emotiva XPA3 GEN3
    Oppo BDP-93,Sony UBP-X800BM, Sony DVP-NS3100ES, WD Live HUB.
    Main: Polk Signature S60
    Center: Polk CSi-A6
    Front High/Rear High In-Ceiling Polk 80F/X RT
    Surrounds: Polk T15
    Sub: HSU VTF3-MK5
    Bed Room;
    Sony KDF-E42A10,
    Marantz SR5010, BDP-S270
    Main: Polk Signature S20
    Center: Polk Signature S35
    Rear: Polk R15
    Sub: HSU STF-2
    Working Warehouse;
    Sony 2100ES
    Polk RTi4 about 15' up the wall
    Old sony 12" Sub
    Mini tower PC with 400GB of music
  • nooshinjohnnooshinjohn Posts: 18,238
    edited August 9
    Look no further, though I am sure Joey will be along soon and recommend Audioquest WEL's and Jesse the MIT Shotgun S-3.... :p
    The Gear... Carver "Statement" Mono-blocks, TriangleArt Reference SE with PS Audio NuWave Phono converter, Walker Precision Motor Drive, ClearAudio Stradivari v2 cartridge and Origin Conquerer Mk3c tonearm, Polk Audio "Signature" Reference Series 1.2TL with complete mods, Pass Labs X1 two channel preamplifier Signed by Poppa himself, PS Audio PerfectWave DAC MkII, Krell Evolution 525a CD Player, Pioneer Elite SC-65, Oppo UDP-205 Blu-ray , Sony XBR70x850B 4k, Polk audio AB700/800 "in-wall" surrounds
  • F1nutF1nut Posts: 40,398
    John, that would be MIT Shotgun S1 only they don't make that series any longer.
  • mdaudioguymdaudioguy Posts: 4,623
    mrloren wrote: »
    I don't know... Maybe if he just used some hardware store zip wire and invested his $100 in the stock market, he'd have enough by now to buy some real nice cables! :p
    7.1 - polk RTi10 x 3 (LCR) : FXi3 x 2 : RTi4 x 4 : Sunfire SDS-12 : Yamaha Aventage RX-A2040 : Adcom GFA-7500 : Squeezebox Touch : DIRECTV : Roku SE : Panasonic PT-AX200U PJ @ 120"
    5.1 - Definitive Technology ProMonitor 800 x 4 : ProCenter 1000 : Klipsch Sub-10 : Pioneer Elite SC-91: DIRECTV : LG OLED55B6P : Roku Premiere+
    Garage Duty - polk Monitor 10s : Pioneer A-717 Integrated Amp : Squeezebox Classic
  • gp4jesusgp4jesus Posts: 1,174
    edited August 10
    BlueJeans 10 gauge. Otherwise, At the risk of tomato’s, 12 gauge minimum of what you settle on.
    Samsung 60" UN60ES6100 LED
    Outlaw Audio 975 Pre/Pro
    Samsung BDP, DirecTV Rcvr, Xbox 360, Dennon LDP, Phillips CD chgr
    Canare 14 ga - LCR tweeters inside; CC outside
    BJC 10 ga - LCR mids, inside & out
    8 ga Powerline - LR woofers, inside & out
    LR: tri-amped RTi A7. Woofers, Rotel 98X amp; M & T, P'sound HCA-1000
    CC: Rotel RB985 -> tri-amped CSi A6
    5 Audio Pro Subs: 1 B1.39: 1 Evidence at each corner
    Surrounds: Hafler XL280 -> AR 12 ga -> RTi A3*
    3 dedicated 20A feeds; APC H15; 4 Furman Miniport 20s
    *Bi-amped by years end
  • Jimbo18Jimbo18 Posts: 1,812
    Second the suggestion of Doug's raw cable. Furez 10ga. or 12ga. raw is cheap and Doug will give you a discount as a Forum member. Terminate them yourself and you will easily be under your $100 total.
    Modest HT - Pio Elite SC-63, RT800i, CS400i center, FXi50 surrounds, Def Tech PF 15TL+, Belkin PF30, Samsung UBD-M7500.
    Even more modest Bedroom - HK AVR 340, Monitor 5jr+ Series2, CS300 center, Furez 10/2, Roku Premiere+
  • pitdogg2pitdogg2 Posts: 10,853
Howdy, Stranger!
