need a DIY adapter
doggie750
doggie750 Posts: 1,160
edited October 2008 in DIY, Mods & Tweaks
Hello Polktech thugs,
Based from my thread http://www.polkaudio.com/forums/showthread.php?p=934102#post934102, I need an adapter for ipod to zune and vice versa. This is feasible as long I could hardwire it correctly and of course I need a schematic and a reader to conduct this. Please advice.:cool:
Similar product
http://www.buy.com/prod/belkin-dock-adapter-for-ipod-shuffle-belkin-dock-adapter-for-ipod/q/loc/101/201935938.html, will not power the zune though
http://www.neocaraudio.com/.......NO LUCK HERE
Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon
Post edited by doggie750 on
  • zingo
    zingo Posts: 11,258
    edited October 2008
    Hard wiring one proprietary jack to another; you have a lot of work in front of you friend. Good luck.
  • zingo
    zingo Posts: 11,258
    edited October 2008
  • zingo
    zingo Posts: 11,258
    edited October 2008
    I hope that helps you with the iPod half, but Zune pin diagrams are hard to find.
  • doggie750
    edited October 2008
    from my resouce:
    here are the pinouts for both units---the pinouts for ipod connectors are everywhere, but there is very limited info on the zune pinout
    ipod pinout
    Pin Signal Description
    1 GND Ground (-), internaly connected with Pin 2 on iPod motherboard
    2 GND Audio & Video ground (-), internaly connected with Pin 2 on iPod motherboard
    3 Right Line Out - R (+) (Audio output, right channel)
    4 Left Line Out - L(+) (Audio output, left channel)
    5 Right In Line In - R (+)
    6 Left In Line In - L (+)
    8 Video Out Composite video output (only when slideshow active on iPod Photo)
    9 S-Video Chrominance output for iPod Color, Photo only
    10 S-Video Luminance output for iPod Color, Photo only
    11 GND Serial GND
    12 Tx ipod sending line, Serial TxD
    13 Rx ipod receiving line, Serial RxD
    15 GND Ground (-), internaly connected with pin 16 on iPod motherboard
    16 GND USB GND (-), internaly connected with pin 15 on iPod motherboard
    18 3.3V 3.3V Power (+)
    Stepped up to provide +5 VDC to USB on iPod Camera Connector. If iPod is put to sleep while Camera Connector is present, +5 VDC at this pin slowly drains back to 0 VDC.
    19,20 +12V Firewire Power 12 VDC (+)
    21 Accessory Indicator/Serial enable Different resistances indicate accessory type:
    1kOhm - iPod docking station, beeps when connected
    10kOhm - Takes some iPods into photo import mode
    500kOhm - related to serial communication / used to enable serial communications Used in Dension Ice Link Plus car interface
    1MOhm - Belkin auto adaptor, iPod shuts down automatically when power disconnected Connecting pin 21 to ground with a 1MOhm resistor does stop the ipod when power (i.e. Firewire-12V) is cut. Looks to be that when this pin is grounded it closes a switch so that on loss of power the Ipod shuts off. Dock has the same Resister.
    22 TPA (-) FireWire Data TPA (-)
    23 5 VDC (+) USB Power 5 VDC (+)
    24 TPA (+) FireWire Data TPA (+)
    25 Data (-) USB Data (-)
    26 TPB (-) FireWire Data TPB (-)
    27 Data (+) USB Data (+)
    Pins 25 and 27 may be used in different manner. To force the iPod 5G to charge in any case, when 'USB Power 5 VDC' (pin 23) is fed, 25 must be connected to 5V through a 10kOhm resistor, and 27 must be connected to the Ground (for examplein 1) with a 10kOhm resistor.
    28 TPB (+) FireWire Data TPB (+)
    29,30 GND FireWire Ground (-)
    Back side of dock connector;
    2 4 6 8 10 12 14 16 18 20 22 24 26 28 30
    1 3 5 7 9 11 13 15 17 19 21 23 25 27 29
    Pins 1,2 connected on motherboard.
    Pins 15,16 connected on motherboard.
    Pins 19,20 connected on motherboard.
    Pins 29,30 connected on motherboard.
    If you disassemble the original apple-ipod-dock-connector-cable and look at the connector itself, on the back side, where it is soldered, you can see the number 1 and 30 (e.g. pin 1 and 30). In this description NUMBERING is INVERSEDin 1 is pin 30 and pin 30 is pin 2, so, don't look at numbers on connector.
    The remote control, iTalk and other serial devices use Apple Accessory Protocol for communication with iPOD. This protocol was introduced with the 3rd generation iPods, and is also compatible with the 4th generation iPods and mini iPods. The connections uses a standard 8N1 (one startbit 8 data bits 1 Stopbit) serial protocol, 19200 baud (higher rates up to 57600 also possible, but speed faster than 38400 may cause problems with large amounts of data), delay of 12 microseconds inserted between end of the stopbit and the beginning of the next startbit (also working without this delay).
    Electrical: high +3,3V low 0V
    default line state: high. Codes used for communication with peripherals are here
    This device may be connected to the firewire computer port by straight cable (TPB+/-, TPA +/- shoulde be twisted pairs in cable)
    Zune Pinouts
    Pin 01 - USB 5VDC(+) (common with Pins 2,3)
    Pin 02 - 5VDC(+) (common with pins 1,3)
    Pin 03 - 5VDC(+) (common with pins 1,2)
    Pin 04 - Unknown (used on travel remote) 1.75 VDC (+)
    Pin 05 - Unknown (used on travel remote) 1.75 VDC (+)
    Pin 06 -
    Pin 07 -
    Pin 08 -
    Pin 09 - Video (+)
    Pin 10 -
    Pin 11 -
    Pin 12 -
    Pin 13 - Audio L (+) (also audio on travel remote)
    Pin 14 - Audio R (+) (Also audio on travel remote)
    Pin 15 -
    Pin 16 -
    Pin 17 - Unknown (used on travel remote) these are likely our trigger
    Pin 18 - Unknown (used on travel remote) these are likely our trigger
    Pin 19 - Ground (common with Pins 22,23,24,and shield)
    Pin 20 - USB Data (-)
    Pin 21 - USB Data (+)
    Pin 22 - USB Ground (common with Pins 19,23,24,and shield)
    Pin 23 - Ground (common with Pins 22,19,24,and shield)
    Pin 24 - Ground (common with Pins 22,23,19,and shield)
    Trigger: Used when an accessory gets connected to inform Zune.
    Godspeed,
    D0661E
    Surrounds: RTis
    Sub:SVS PB12-Plus/2
