bad driver on ls 50?
ken brydson
I have a pair of LS 50's that I got in 1996. They've always sounded great but recently one of them has developed some distortion and a "buzzy" sound. I thought it might be my amp or speaker wires but after some fiddling isolated one of the drivers that was making the sound. I popped it out and disconnected the wires and the speaker sounds good again. Could it be something else other than the driver itself like internal wiring or crossovers or?? I don't want to spend the $$ to repace the driver and have it be something else.
Post edited by ken brydson on
I'm not clear about something, did you disconnect the driver in question and then everything else sounded ok or did you disconnect it and then re-connect it which resulted in that driver playing ok again?Political Correctness'.........defined
President of Club Polk -
I left it disconnected. The remaining speakers sound good now because the distortion was coming from the one I had disconnected. I ordered a new one today. The CS guy I talked to was fairly sure it was the driver.
Ok, it sounds like a bad voice coil. You could swap the questionable driver with a known good one and if it still sounds like crap, then you have a bad driver. Let us know.Political Correctness'.........defined
Will do. They're shipping it Monday so I should have it by Wed
