Tweeter noise
MxStYlEpOlKmAn
MxStYlEpOlKmAn Posts: 2,116
edited December 2002 in Troubleshooting
I know I dont have blown tweeters, I can only hear this when theres no music, and if I switch the mains to the surrounds, the noise is gone - its like a light treble noise that comes off and on - on the tweeters. Newayz, what do yall think is the problem? i cant really describe the noise....but do you know what the problem is?
Damn you all, damn you all to hell.......
I promised myself
Damn you all! - ATC
Post edited by MxStYlEpOlKmAn on
  • gidrah
    gidrah Posts: 3,049
    R(adio) F(requency) I(nterferance) would be my guess. Shielded cables might solve this.
    Or it might be a noisy amp/preamp. Does it go away with no source selected? With no source selected, if you turn up the volume, does the noise increase?
    Make it Funky! :)
  • MxStYlEpOlKmAn
    the noise sounds the same at ne volume, it also does this on my mains 2 klh'
    I promised myself
    Damn you all! - ATC
  • goingganzo
    goingganzo Posts: 2,793
    amp hum ro rfi or a bad ground a ad ground will do that too
  • gidrah
    gidrah Posts: 3,049
    You could take it down to the basic.
    1. Disconnect all equipment and antennae
    2. Use the shortest speaker wire. 2ft per will suffice.
    3. Connect a piece of wire from phono ground to known ground.
    4. Listen to CD (no source) is hum/hiss present?
    5. If yes, then the noise is probably within your components and it's something you must live with.
    6. If not, then reconnecting your stuff with a listen between each step should be your answer.
    7. If it's still isn't present until you disconnect the ground I'd consider a 3 prong plug.
    Good luck! Let us know how things pan out as I'm sure others can benefit.
    Make it Funky! :)
  • MxStYlEpOlKmAn
    ill do all that when i get my new set of wires for christmas, but I know it isnt just one source. IE: it does it on all formats.
    I promised myself
    Damn you all! - ATC
