bi amp or single amp
goingganzo
goingganzo Posts: 2,793
edited December 2002 in Electronics
would it be better to bi amp at 100 wpc or get a amp that has 200 wpc?
Post edited by goingganzo on
  • gidrah
    gidrah Posts: 3,049
    I've been checking out bi-amping at some other sites. From what I gather if done correctly with the correct amps, speakers, & wire it can be really sweet and be quite an improvement. If not done correctly you can damage your speakers and/or amps.
    I'd go with a 200wpc and bi-wire. Or if the 100wpc amps in question are bridgable, go with a bi-wired dual mono configuration.
    Make it Funky! :)
  • trance72
    trance72 Posts: 18
    your going to need 2 amps. run your highs on the 100wpc L/R and your subs on the 200wpc L/R
    a true audiophile is never satisfiyed
  • faster100
    faster100 Posts: 6,124
    Actually i have read to use equal size amps and pref. the same brand. I have done this with my rti70's, I have a 2 channel amp with 4 outputs(speakers A&B) and at 165 wpc i put each output on each the tweeter and woofers, seemed to work good, can't say i noticed a difference when i switched back to regular bi-wireing them on 1 output each speaker. The highs actually are not so bright as it doesnt have 165 going straight to each one.
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
