Psw450 auto on switch
Phildogg
Hey, My question is this; my PSW450 doesn't seem to shut off by the auto on switch even after the signal from my receiver has been turned off for more than 15 minutes. The sub stays warm like it is still on and the light doesn't go off. Any ideas?
Melissa Wooldridge
Post edited by Phildogg on
Hello,
One of the common causes is the owner not getting the three position selector, on the sub-woofer, correct. Make sure you have the selector all of the way to the left (closest to the heat sink assembly) to the "auto" position. The labeling is not clear, but set it to the left position, this should solve the problem.
Regards, Ken Swauger -
I had the problem too........the labeling is not only not clear, it is totally bassackward!
it should be all the way to the left as you face the rear of the sub from the front. If you're looking at the back panel, it is bassackward. I changed it and now the little light turns red when everything is off, just as it should.
