equalizer with Denon 3802
bounty5
bounty5 Posts: 20
Is it possible to hook up and equalizer to a Denon 3802? I have one available, but do not see any equalizer jack(s), nor anything listed in the instructions. How, or can this be done? and if so, what gets connected to what?
tks
Post edited by bounty5 on
  • jgido759
    jgido759 Posts: 572
    edited November 2002
    I'm not familiar with that particular receiver however, if you have a "Tape Monitor" or "Tape Loop" connection, that is where you would connect your EQ.
    Oh, you hate your job? Why didn't you say so? There's a support
    group for that. It's called EVERYBODY, and they meet at the bar.
    -Drew Carey
    There is a very fine line between "hobby" and "mental illness."
    -Unknown
    My DVD Collection
  • polkatese
    polkatese Posts: 6,767
    the 3802 I think is the same as the 2802 which I just recently sold, and I was in the same situation (i.e. own an equalizer) that I wasn't able to use. What's missing from the 3802 I believed was an outside loop (pre out - main in) connector that would allow you to add equalizer, dynamic compressor/expander, etc) such as the denon avc-3030 (that I still owned). You could put your equalizer in one of the path of the source (either one of the tape, cd, dvd) and use it exclusively for that path, or you could add a multi input switch that connect all the sources, and pick a fix input to your 3802 (not the best route, since then you are not using most of your source controls on the receiver)..
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
