Flat Sounding Sda 1
ONEFLESH
ONEFLESH Posts: 5
edited November 2002 in Troubleshooting
I have a set of old SDA 1 speakers. Seems like the left speaker sounds flat and lacks treble. I remember replacing the tweeters some years ago. Is there some tests I can do to determine if my drivers/tweeters are at fault. Or if it is a crossover problem???
Jim
Post edited by ONEFLESH on
    F1nut Posts: 49,708
    ONEFLESH,
    Welcome!
    Try swapping the tweeters, if you still have the problem with the left speaker then you've probably got a xover problem. Let us know.
