Best dvd player
ljd0004
ljd0004 Posts: 6
edited February 27 in Clubhouse Archives
Can someone recommend the best dvd player for $500 and from where?
Post edited by RyanC_Masimo on
  • PETERNG
    PETERNG Posts: 918
    edited September 2001
    For about $445, u can buy the above DVD player, I believe it's one
    of the best DVD player in the market for that price range, here are
    its specs:
    Progressive Scanning (480P) output for true-to-film picture playback of DVD movie discs1
    4:3 Shrink Function w/ Letterbox Zoom & Shift lets you watch DVD movie discs in their original aspect ratio on a 16:9 wide screen to preserve the high picture quality of progressive output
    54MHz/12-bit Video D/A Converter uses 54MHz oversampling to help bring out the amazing picture quality offered by our progressive-scan DVD players
    DVD-RAM Video Playback Capability
    MPEG Digital Noise Reduction (Mosquito/Block/3D)
    Picture Control (Brightness, Color, Contrast, Sharpness)
    Gamma Correction allows a choice of different gamma settings to help bring out detail even in dark scenes
    2-Dimensional Sharpening Filter
    Monitor Select allows for connection to a standard TV, CRT Projector, LCD Projector or a Projection TV
    Switchable Component Video Out (480P/480I)
    Advanced Surround (V.S.S.) allows for a remarkable surround sound effect even while only using the front two speakers2
    Headphone Surround (V.S.S.) provides great sound even with headphones
    Cinema Mode for cinema-like luminance and color with improved detail even in dark scenes
    Dialogue Enhancer makes the dialogue channel clearly audible over the other sound channels
    Disc Stabilizer for improved playability
    Still Picture Display (I/P/B) freezes an image to allow for precise picture quality adjustments
    Auto Switching Field/Frame Still for added versatility
    Frame Advance (Forward & Reverse) for incredible control
    Black Level Control
    192kHz/24-bit Audio D/A Converter provides greater sampling rates and bit depths than standard audio formats for amazing fidelity and sound quality
    Built-in DTS®3 & Dolby Digital®4 5.1 Channel Surround Decoder with Speaker Setting delivers crisp, theater-like sound
    3-Mode Digital Re-Master Processing for CD/DA Playback
    Virtual Battery Operation
    Audio Only Function (Video Circuit OFF)
    Dual Digital Audio Out (Coaxial/Optical)
    Headphone Jack with Volume Control
    Dynamic Range Compression
    Illuminated Joystick Remote Control
    DVD/CD Text Display
    Disc Memory
    CD-R/RW Playback5
    Twin Laser Pickup for DVD/CD playback
    Chapter Preview helps to refresh your memory of a movie by showing you the first 3 seconds of each previously viewed chapter
    Hi-Speed Smooth Motion Scan: 5 Speed up to x100 allows crystal clear scan quality while locating desired locations on a disc
    On-Screen Menu Icons to help guide operation
    Energy Star® Compliant for low energy output
    Remote Control
    U can buy it @:
    http://www.video-direct.com/panasonic/dvd/dvd-rp91n.html
    Hope these info help....
