DIY speaker stands, unconventional style....can you dig it?
surfntomm
surfntomm Posts: 185
edited September 2007 in DIY, Mods & Tweaks
Hey there, been spending the past couple weekends making these bad boys out of 3/4" plywood and 1/8" plywood with oak veneer on it.
This was my first wood DIY project ever, only other DIY other than my pc is my speaker cables/hoses you see in the pictures that are to come. So far im pretty happy with the outcome, all that is left is to stain the wood which shouldnt be too hard.
I used a dremel with a routing bit, sandpaper, files, jigsaw, and a circular saw and lots of sweat and hardwork!! ;)
Let me know what you guys think of them so far....They are not mounted onto the tile so do not fret if they are not centered on the tile. This is just a temporary installation since i am only home for the summer and i needed to check out how they look and sound.
So far they sound better than my sanus wood stands, although these are hollow on the inside (top is sealed), i can fill it with something to add weight to lower the center of gravity but so far the large slab of granite does the trick i believe.
All thoughts and opinions are welcome....cheers!
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited August 2007
    Very nice, but looking at them only one thing comes to mind - an active woofer in each tuned to the cabinet, folded horn or tuned quarter wave maybe......
    Cheers,
    Russ
  • engtaz
    engtaz Posts: 7,677
    edited August 2007
    Very nice. nice design. Congrats
    engtaz
  • SolidSqual
    SolidSqual Posts: 5,218
    edited August 2007
    And who wouldn't want two Lsi speakers pointed 2 feet from your ears. God I love this hobby!
  • hypertone
    hypertone Posts: 150
    edited August 2007
    Those are awesome. Nice job.
  • Midnite Mick
    Midnite Mick Posts: 1,591
    edited August 2007
    How do they look with the concave curvature in the front?
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
    heiney9 Posts: 25,716
    edited August 2007
    Nice work !! :) . At all costs get rid of the hollow area. That will resonate like crazy. Fill it with sand, shot or cement. Aesthetically those are really nice, for pure functionality not so sure.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited August 2007
    Nice work there.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • janmike
    janmike Posts: 6,146
    edited August 2007
    Nice design. Any plans for a finish?
    Michael ;)
    NORTH of 60°
  • honda cber
    honda cber Posts: 267
    edited August 2007
    i wouldve run the grain vertically. maybe harder to bend, but it might not look like plywood. as they are, i would use some kind of black textured finish. you could hide the grain. those things are going to be heavy when you fill them up with whatever. make sure they can support the weight.
    those sure are nice computer speakers... i definitely feel you there...
    a
    gear list:
    1 down, 4 up....
  • McLoki
    McLoki Posts: 5,231
    edited August 2007
    I think they look great. You can add a lot of rigidity without a lot of weight by filling the stands with great stuff expanding foam. (I would wait for a second opinion on this before I did it, but it should work....)
    Looks nice and is the perfect height for your computer desk.
    Michael
  • honda cber
    edited August 2007
    uh, i meant to say "i would use 'duratex'." seems like a perfect solution.
    http://www.acrytech.com/store.asp?pid=14119&catid=19771
    a
    gear list:
    1 down, 4 up....
  • honda cber
    edited August 2007
    oh yes, but dont use too much foam, too fast, or your cabinets will explode!
    a
    gear list:
    1 down, 4 up....
  • surfntomm
    edited August 2007
    Hey guys, thanks for the comments i appreciate it.
    In terms of resonating i was deathly afraid of that, hence i am testing them out right now before i finish them to see whatsup. They are hollow but no resonating actually, i put a bit of bracing inside as well to help with that. If i want to in the future i can put that expanding foam inside but as i see it now there is no need.
    I would have loved to have the grain running vertical as that would be so much.....how do you say "sexier" but it would be impossible to bend. it was hard enough as it is currently. i need to rout the back down to pretty much just the veneer and i had a few hairline cracks cus the wood just didnt want to bend. getting the wood a bit moist helped with its pliability if that is even a word.
    I will finish it with a stain but ill avoid the finishing glossy coat. I am not a fan of the textured finish, the grain looks great in person and it would be a shame to hide the beautiful oak grain.
    The curvature is exactly how i wanted it and it is very cool. I have the top with a sort of rake towards the back so its tilted upwards about 2-3 degrees. This isnt my permanent rig so thats why the speakers are so close together and close to my face. Im living at home with my parents for the summer before i go back and finish my last year in college.
    I think my best option to fill it is with cement in the bottom but that will be tricky enough as it is.
    FYI they are 30" tall and far outperform the natural sanus stands i had before sitting on marble slabs.
    thanks again for the comments
  • dane_peterson
    dane_peterson Posts: 1,903
    Kinda reminds me of Sonus Faber Cremona Auditor stands. I'm a big fan of rounded wood though--nice job.
  • michael_w
    michael_w Posts: 2,813
    They look great and should pop when you hit them with a stain!
    Are you using cardboard to channel heat from your motherboard??
