Center Channel Question
tpeter
tpeter Posts: 65
edited September 2002 in Speakers
I have the LSi/C Center channel and was wondering what should i set this as in my setup, Large or Small? What differences does this make as well?
Polk LSi 15
Polk LSi/C
Polk LSi/FX
SVS Ultra
SVS PB3000
Monolith 15 THX
Denon 3700h "switching to Onkyo rz50"
Monolith 7 AMP.
Post edited by tpeter on
  • hoosier21
    hoosier21 Posts: 4,408
    manual says set it to small, I would do this if I were you. Doing this removes the bass from your center speaker.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • trubluluc
    trubluluc Posts: 2,067
    yep yep, let the bass go to your psw650.
    Less vibration to your tv.
    -Luc
  • Dr. Spec
    Dr. Spec Posts: 3,780
    Small - Agreed. If you can adjust the x-over freq., pick 100 Hz or 80 Hz - any higher MIGHT make certain male voices sound a bit thin (a problem I had on my previous receiver).
    Doc
    SVS
