Vibration problems
dylan
dylan Posts: 453
Ever since I got an SVS sub, DVD's skip during heavy lfe. CD's seem ok on heavy bass stuff (on a Denon player), but the Toshiba 2715 skipping is really annoying. I put the player on 2 towels (the towel mod, patent pending!) to make sure it was just the vibrations, and it played fine, so I'm blaming Toshiba for not being very flexible.
So... Vibrapods cut it way down, but it still happens. So usually heavy lfe parts are the exciting parts of the movie, so bam bam bam -- skip -- silence -- silence -- and it moves on. I also just bought a new equipment rack, with the stands filled with sand, but it did the same thing on my old stand.
Any ideas for vibration absorption? Foam? Dynamat? Styrofoam? Vibrapod sandwich?
Post edited by dylan on
  • RuSsMaN
    RuSsMaN Posts: 17,987
    edited September 2002
    Did you bake the vibrapods?
    You actually might want to try adding some weight to the dvd player. Get a $2 mousepad, set it on top of the player, and add a 3-5lb weight on top. You can deal with the 'ugly' factor later, I'm interested to see if this helps.....
    Cheers,
    Russ
    F1nut Posts: 49,781
    Try "Big Feet" from Audioquest, made from sorbothane gel. This solved all my vibration problems.
  • scottvamp
    scottvamp Posts: 3,277
    Move DVD player farther from sub.:)
  • Frank Z
    Frank Z Posts: 5,860
    Get rid of all hip hop/rap music!
    F1nut Posts: 49,781
    That's not music, it's just noise.:lol:
  • gidrah
    gidrah Posts: 3,049
    I'd look into a piece of rock. Granite, slate, or marble for under your sub. Put this on top of those towels and your problems should subside.
    Make it Funky! :)
    F1nut Posts: 49,781
    Wouldn't that create a "HARD" sound?
  • gidrah
    gidrah Posts: 3,049
    I've never heard of soundwaves being hard or soft.
    You're just in that F1 mode. That's okay. I'll be here.
    Make it Funky! :)
    F1nut Posts: 49,781
    It was meant to be a pun, but you can have a hard or soft sound depending on room acoustics, etc.
  • gidrah
    gidrah Posts: 3,049
    From what I've heard/read from people that use a downfiring sub is that this kind of treatment is THE way to go. Front, side, & top firing subs can also benefit, but not usually to the same degree.
    If I had a sub with a sound that I considered to be 'hard', I'd be a happy camper.
    Make it Funky! :)
    F1nut Posts: 49,781
    Do you use a "stone" platform?
  • gidrah
    gidrah Posts: 3,049
    Nope. I use spikes. But my sub is a front-firing design with smaller drivers. I'm also using this in a pretty small room with a wife that has the hearing of a bat and a daughter that sleeps like a shrew. Until recently I also had a tenant living upstairs.
    Make it Funky! :)
    F1nut Posts: 49,781
    We all have a cross to bear :D Good Night!
  • trubluluc
    trubluluc Posts: 2,067
    If possible, as scott suggests, move the sub farther from your rack.
    Also, get some foam.
    I'm using 1/2" compressed closed cell foam under my subs (front firing) and it helped alot.
    The sound is still big and deep, but the lamps no longer rattle.
    For a down firing sub, I would put a piece of stone over the foam. Insulating the sub from the floor, but bouncing the sound up into the room.
    -Luc
  • dylan
    dylan Posts: 453
    edited October 2002
    Thanks everyone for the suggestions. I tried a bunch of weight on it last weekend, but no luck. I thought that was going to be the ticket.
    How far do you think the slate should extend past the sub? The foam sounds good too... is that a Home Depot kind of deal?
    Thanks!
  • Ron-P
    Ron-P Posts: 8,516
    edited October 2002
    As long as the sub sits on the slate, it does not matter how far out it extends. Your landscape supply stores will carry the slate. I picked up a 2" thick, 1.5' x 2' slice for $20. Of course, I did this for increased preformance from the sub, I did not have any skipping problems.
    Good Luck! Have you thought about putting the player on spikes?
    Peace Out~:D
    If...
    Ron loves a film = don't even rent.
  • trubluluc
    edited October 2002
    dylan-
    I picked up my foam from REI.
    But home depot may have it as well..
    It's the thin blue stuff just visable in a couple of shots in the "system showcase".l
    -Luc
