Hanging Rear Center
iDoNtKnOe2k1
iDoNtKnOe2k1 Posts: 30
edited September 2002 in Speakers
Well i have an old cs275 that i would like to hang as my rear center with my brand new Denon 3802 :)
My question is that:
If i screw in screws into the speaker will it damage the speaker in anyway...
I would like to screw in some brackets to hang the speaker on the wall (actully its hanging by some rope now)
Post edited by iDoNtKnOe2k1 on
  • RuSsMaN
    RuSsMaN Posts: 17,987
    Shouldn't hurt a thing, except maybe re-sale value....
    Just use common sense before you get your drill on, maybe pop a driver out and see what-is-where first.....
    Cheers,
    Rooster
  • trubluluc
    trubluluc Posts: 2,067
    The Russman is right.
    I called ken at polk customer service before drilling my cs400, you can see it hanging in "system showcase". He said if you drill on the sides, it would be ok.
    I used the omni mounts, worked out well.
    -Luc
  • TroyD
    TroyD Posts: 13,077
    Rope? Rope? Jeezuz......
    I generally prefer silver duct tape for my half-assed projects.
    BDT
  • nascarmann
    nascarmann Posts: 1,464
    BDT.....you half-assed:lol:
    Oh, the bottle has been to me, my closes friend, my worse enemy!
