dammaged foam suround
goingganzo
goingganzo Posts: 2,793
edited September 2002 in Troubleshooting
i have a 12 inch car dub with foam suround it has a 2 inch cut in it i want to mend the cut if all posible heres a pic of it
Post edited by goingganzo on
  • HBombToo
    HBombToo Posts: 5,256
    Has any1 ever considered the glue in a tire repare kit?
    My thinking is how the rubber on the tube will melt a little and bind the seem then the glue dries slower and becomes reinforcement.
    I'm trashed so forgive my rant. Its just nice not to be in a vehicle. 3k miles in 1.5 weeks is brutal when your 2 year old throws many tantrums.
    Next project is equipping the Yukon with an HT system.
    ***WAREMTAE***
    F1nut Posts: 49,709
    Try some silicone or take it to a pro shop and they can replace the foam.
  • RuSsMaN
    RuSsMaN Posts: 17,987
    Is that a 'Kicker' sub? Just curious, thought I recognized the stitch pattern....
    Cheers,
    Rooster
