Build your own SDA A1
jrausch
jrausch Posts: 510
edited August 2002 in Speakers
I was digging through some old paper work and found this document from Ken Swauger. I told him I would convert it to .pdf and never got around to it. This is for building the discontinued A1 modual that keeps you from destroying your SDA's while using a non-common ground amp setup. This includes all mono block and some single chasis dual/multi mono block designs (i.e. Adcoms 5802). So for you SDA fans who want to upgrade to more mono block power, here's your chance to improve your system. If you document your processes and take pictures, you can send them to me and I’ll upgrade the file.
Until then enjoy!! :)
See next message for the download
"The only way to get rid of a temptation is to yield to it."
Post edited by jrausch on
