Bass Shakers Application
BobMcG
The sofa I use in my HT room is also a queen size pull out sleeper. Does anyone know if bass shakers could possibly be rigged for this application or if it's impossible. I personally can't see how it could be done but maybe someone has found a solution.
AIIRC
AIIRC
Post edited by BobMcG on
While we're on the topic of bass shakers, are those things any good? How do they work exactly? It seems to me like a PSW1200 would be a good bass shaker.
Aaron -
Yes, they will work on a sleeper, as long as you can attach them to a solid piece of the frame. They don't need a whole lot of power, 50 watts or so. (an old rec. will work fine). They essentially work like a speaker, but the transducer does not produce sound, it produces vibrations.
Your sub will give bass tones, and vibrate some, but the bass shakers used in conjunction will really make some impact in your seating position. You WILL feel T-Rex run by.....
I've heard 2 for each sofa, 1 for each chair, used in an HT setup. No power required, they are a speaker in essence, and hook-up is via standard connectors with speaker wire.
Cheers,
Russ
Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
