Bi-amping SDA's ?
nascarmann
nascarmann Posts: 1,464
edited July 2002 in Speakers
When you bi-amp the SDA's....do you need to run the AI-1 or is this just needed for mono blocks and bridged amps?
Oh, the bottle has been to me, my closes friend, my worse enemy!
Post edited by nascarmann on
  • hoosier21
    hoosier21 Posts: 4,408
    edited July 2002
    Only for Mono block. If you ahve an extra AI-1 I will take it.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
    F1nut Posts: 49,708
    edited July 2002
    King,
    As long as the amps are the common ground type and are by the same maker (same specs) you don't need the AI-1. If in doubt about being common grounded check with the manufacturer. Make sure that you remove the jumpers on the speakers binding posts. Did you pick'em up already?
  • nascarmann
    edited July 2002
    hoosier...I'm onlygetting one so I will need to hold on to it until I know for sure I won't need it.....:(
    F1nut....looks like we are a go for Saturday? Not for sure on that though....:confused:
  • nascarmann
    edited July 2002
    F1nut.....to follow up on this...they are the same. The best set-up would be one amp for left and one amp for right? This still looks like there is not a ground between the 2 channel? Am I not thinking right?
    F1nut Posts: 49,708
    edited July 2002
    Ok, I'll do the best I can......
    You use one amp for the high frequency and the other for the low.
    AMP 1 Highs - run a speaker cable from the amps right output (positive & negative) to the top inputs (pos. & neg.) of the right speaker. Run a speaker cable from the amps left output (pos. & neg.) to the top inputs (pos. & neg.) of the left speaker. You have now connected the high frequencies.
    AMP 2 Lows - run a speaker cable from the amps right output (pos. & neg.) to the bottom inputs (pos. & neg.) of the right speaker. Run a speaker cable from the amps left output (pos. & neg.) to the bottom inputs of the left speaker. You have now connected the low frequencies.
    MAKE SURE YOU REMOVE THE JUMPERS from the binding posts on the speakers before bi-amping.
    Since both of your amps are the same (make sure they are the common ground type, most are) you will not need the AI-1. Hook up the pre/amp and source(s) and turn up the volume.
    Hope this helps.
  • nascarmann
    edited July 2002
    Yeah......I understand hooking it up either way. To me it looks like the best way to hook them up is to run L pre-out to one amp and use that amp to run the high and low freq for the left speaker. Do the same for the R side. I think then you would need to use the AI-1? Do you see what I mean? Amp A will run the left speaker and amp B will run the right speaker. Is this not the best way to set them up?
    F1nut Posts: 49,708
    edited July 2002
    No, I dug out the Polk manual and they recommend setting it up like I posted. "In Polk We Trust"!
  • nascarmann
    edited July 2002
    10/4 ON THE MANUAL......:D
  • madmax
    madmax Posts: 12,434
    edited July 2002
    Half of the fun (and most of the frustration) is trying it all the different ways.
    madmax
    Vinyl, the final frontier...
  • nascarmann
    edited July 2002
    Agree madmax....but I don't want to damage the speakers! Your input would be appreciated............;)
  • madmax
    edited July 2002
    I've tried mine both ways. So long as you use the AI-1 with the SDA's while driving seperate channels (one amp driving left and another driving right) you wont damage anything. I wont say which is better because I keep trying them both ways. Each way is better in some aspects. So far I have not used the interface because my amps don't seem to have any potential difference between the grounds. I think.
    madmax
