Mounting R15i's to OmniMount Systems 53 RST UMK
zeltar
zeltar Posts: 2
edited July 2002 in Troubleshooting
Hopefully a simple question:
What type of screws should I use to mount the bracket to the speaker itself? The holes on the back of the speaker appear to NOT be threaded, so I probably only get on chance.
Thanks for your input.
Post edited by zeltar on
  • mantis
    mantis Posts: 17,056
    edited July 2002
    Any reason you don't want to use the key hole instead???
    Just personally not a fan of aftermarket brackets.Once you screw them into the speaker...thats it.They should have provided you with wood screws.Just pop out one of the drivers to see where the crossover is so you don't put a screw through it.
    Dan
