RT25i
avilladiego19
avilladiego19 Posts: 7
edited June 2002 in Speakers
I purchased a pair of Polk PT25i speakers a couple of months ago. They are connected to a 105 watts per channel Denon receiver. I was curious to how low these speakers would go and popped a cd with lots of bass on it in my cd player. When the bass started, i thought that i heard my window shades rattling, but it was the air comming out of the power port on the back of the speakers. Is that normal????
Post edited by avilladiego19 on
  • GuitarheadCA
    GuitarheadCA Posts: 400
    edited June 2002
    avilladiego,
    Yes, and no, it's sorta normal. The RT 25's are designed to recreate great treble and midrange, and enough bass to blend with a sub. Having owned them, I can testify that they're great speakers. However, they can never come close to the bass response of that of a sub. The Port noise you heard is going to happen when you drive them hard with alot of bass. Especially if the driver is visibly moving a large amount, there is tons of air that needs to move through the port. Usually the port noise is masked by the music, but if you drop in like a synthesized bass CD with tons of bass, and not much treble, you're going to hear the noise.
    GuitarheadCA
  • mantis
    mantis Posts: 17,056
    edited June 2002
    Nice post!!
    Dan
  • MxStYlEpOlKmAn
    MxStYlEpOlKmAn Posts: 2,116
    edited June 2002
    hearing this noise dont damage the speaker right?
    Damn you all, damn you all to hell.......
    I promised myself
    Damn you all! - ATC
  • mantis
    edited June 2002
    It means you pushing them alittle to hard.
    Dan
  • scottvamp
    scottvamp Posts: 3,277
    edited June 2002
    Good call Mantis:D I pretty sure the 25's were not designed to accurately produce heavy bass. But that is just IMO. :rolleyes: But in my second HT they sound awesome with my AR 12" sub.
    avilladiego19----Hint! Hint!;)
