RTi with new CS
So I have some RT 35i's that I like a lot and the look. I want to get the new CD40i becuase it's height is PERFECT for where I need to place it. Will they match ok or should I upgrade (as I can for one year from purchace at CC) to a new bookshelf. My main concern is I was hoping for a replacement to the 55i and to upgrade to that. What do you all think the best course of action is?
Post edited by eaadams on
If you like the RT35i, get the new center and check it out. I think you will find that they will go together quite well....
If it ain't broke, don't fix it.
TroyI plan for the future. - F1Nut -
i would say get the center and if it sounds good then dint trade out the 55
