Psw150
NDTA
NDTA Posts: 83
edited May 2002 in Troubleshooting
My PSW150 start humming, please advice how to fix this problem, this problem just started about 2 weeks, never happen before.
Thanks for you help
Post edited by NDTA on
  • mantis
    mantis Posts: 17,056
    edited May 2002
    you could have a bad grounding problem or the cable is becoming a antenna.
    Dan
  • [Deleted User]
    [Deleted User] Posts: 7,658
    edited May 2002
    Hello,
    Welcome to the Forum, I'm sorry there's a problem with your system. A few basic trouble shooting items to check. What happens to the humming if you disconnect all of the incoming cables/wires (not the AC power cord, of course) from the sub-woofer? This will help determine what might be the cause. If the sub-woofer continues to hum, give me a call at 1-800-377-7655 extension 891 and I'm sure I can help.
    Regards, Ken Swauger
