RM7200 in Ceiling Flush Mount
benochs
benochs Posts: 2
edited May 2002 in Speakers
Does anyone have an opinion of whether or not you could do a flush mount in ceiling mount with the RM7200 rear satellites? I am considering taking these back to the store and was curious if I built a box and housed these speakers above the ceiling, if it would turn out ok... Or should I just totally hang up the idea and take them back to the store..
Post edited by benochs on
  • mantis
    mantis Posts: 17,056
    edited May 2002
    You sound like you need Inceiling speaker's.What the problem, your room cannot support good position for rears or is it the better half can't do it.
    Dan
