RT2000P lower array x-over broken
Norm E. Dickey
I purchased the pair from a friend of a friend of a friend (cheap). I knew they had lower array problems but when used with a sub(PSW150) they sound great. I hope to fix them myself, fiddling is fun. Does anyone know where I can get the schematic for the lower x-over? I believe that the problem lies there. The drivers are fine but they do not work when speaker level or line level inputs are applied. I will run these bi-wired so I'm not concerned of the sub-amp not functioning. I may purchase a pair of outboard x-overs and remove the old x-over/amp combo. Anybody know the x-over point for the lower array? thanks dudes
Welcome to my home, enter of your own free will and leave a bit of the happiness that you bring. -D
Post edited by Norm E. Dickey on
I knew they had lower array problems. The drivers are fine but they do not work when speaker level or line level inputs are applied.I will run these bi-wired
Aaron -
The straps- Yes, they were in place when I attempted full range speaker level input operation, I removed them for line level input sub-amp use as per the instructions. I also removd the straps and hooked up just the lower binding posts, which should activate the bass drivers only.
If I go to an non-OEM crossover, without a built in amp, I will be running these bi-wired ,loosely speaking, because my main amp will be supplying juice for the entire speaker, using both sets of binding posts and 4 wires per channel.Welcome to my home, enter of your own free will and leave a bit of the happiness that you bring. -D -
could your amp be bad? take the x-over out and check for burnt circuet bord and restors make sure the amp works and try and plug it in. when you use the rca input do the sub work?
I've taken apart both amp assembies and can't find any burn't or obviously broken parts. It does not function in any wiring configuration. The green LED does come on, so I know it is getting juice.Welcome to my home, enter of your own free will and leave a bit of the happiness that you bring. -D
i bet the jumpers were still on and llfe was sent in i bet the imput stage is bad on the amp you can fix it 2 ways go buy a replacement sub anp from polk or by pass the amp and get a sub anp http://www.acoustic-visions.com/300792.htm like 100 bucks or less
I am most likely going to pick up non-OEM amp(s) and bi-amp the things. Partly because when I post the results, people will say that the 2000's can't be bi-amped. Mainly, because the customization makes them more 'mine' and it's fun.Welcome to my home, enter of your own free will and leave a bit of the happiness that you bring. -D
i was reading the demintions 8-1/4" wide 10-5/8" hight, 4" deep
cut out , 71/4" wide, 9-5/8" high
polk plate size is 8"wide, 8" high
so there might be some cutting on the cabinet. to make the new amp sub plate to work from accoustic vsions.. rt-7 mains
rt-20p surounds
cs-400i front center
cs-350 ls rear center
2 energy take 5, efects
2- psw-650 , subs
1- 15" audiosource sub
lets all go to the next ces.
