Onkyo TXSR-600, 4 ohm speakers
grathol
Hi there,
I ordered an Onkyo TXSR-600 receiver and some Polk speakers (4 RTi28's, 1 CSi30, and 1 PSW250). The speakers are 4 ohm speakers according to the owners manual, and Onkyo's web site (http://www.onkyousa.com/newprod.cfm) lists this:
80 W/Chx6 into 8 ohm(20Hz-20kHz)
105 W/Chx6 into 6 ohm(20Hz-20kHz)
I realize I only have a 5.1 setup (I don't plan on hooking up a rear center yet) but the 2 power outputs are listing 6 and 8 ohm outputs whereas the speaker is 4 ohm. I don't have the receiver yet (special ordered, apparently they're hard to come by as they are so new) but I'm wondering if there will be any problems/damage to the speakers or amplifier due to the lower impedance. Can anyone help me out or direct me somewhere that I can figure out what might happen? Thanks.
Post edited by grathol on
The plot thickens.... I did a little calling around and some research on the web, along with the owners manuals, and here's what I've come up with:
The Polk web site lists the RTi28 speakers as "Nominal 8 ohm impedance", and the CSi30 as "Nominal 8 ohm impedance"... when you download the PDF manual is says it is "Compatible with 8 ohm outputs"... However, the back of the actual printed manual for each of these products lists themselves as a "Nominal 4 ohm impedance." I tried calling Polk, and they weren't open today (Sunday) so I'll try calling again tomorrow, but does anyone else here have any more information than I about this? -
i think the rt-28i & cs-30i are 8 ohms, the only polk you should worry about is the polk lsi line they are 4ohms.
so you should be alright, go ahead and hook them up and injoy.
and wecome to the polk forum, grathol. rt-7 mains
rt-20p surounds
cs-400i front center
cs-350 ls rear center
2 energy take 5, efects
2- psw-650 , subs
1- 15" audiosource sub
lets all go to the next ces.
