FS: Jeff Rowland Design Group Model One Amplifier
RuSsMaN
Made from 1989-1994, MSRP $3100. Serial number 1331
Features:
Output power 60 watts RMS continuous, 8 ohms
120 watts RMS continuous, 4 ohms
215 watts RMS continuous, 2 ohms
Power Bandwidth 0.3 Hz to 300 kHz, -3 dB
Slew Rate 70 volts per microsecond
THD and Noise Less than .025%, 1 kHz, 8 ohms 20 watts
Less than .035%, 1 kHz, 8 ohms, 60 watts
Damping Factor Greater than 200, 20 Hz to 20 kHz, 8 ohms
Greater than 85 100 kHz, 8 ohms
Output Current 22 amps peak, continuous 55 amps peak, 0.1 ohm, 20 msec, 1 kHz
Overall Gain Selectable: 20, 26, 29.5, 32 dB Sensitivity 136 mV, 1 watt, 8 ohms
Input Impedance Selectable: 100k, 20k, 600 ohms
Common Mode Rejection Ratio Greater than 90 dB
Bridged Mono Output Power 240 watts RMS continuous, 8 ohms
360 watts RMS continuous, 4 ohms
500 watts RMS continuous, 2 ohms
Amp is in outstanding condition. I've just installed a new power-on bulb, and amp will ship with an additional spare bulb, and a tool to install it. This is, without a doubt, one of the best sounding solid state amps on the planet, past or present. Facia is clean, with only a couple VERY small, I mean TINY marks around the outer edge - maybe 1/2 mm x 1mm. Top cover and heat sinks are fanatastic.
$1100 to your door
Cheers,
Russ
Features:
$1100 to your door
Cheers,
Russ
Post edited by RuSsMaN on
Hi-brow stuff there bro. Very nice.......
Rowland designed stuff to last. Consider that build quality compared to most 200-300 wpc stuff built today.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Damn straight Dennis. That amp will drive just about ANYTHING. The selectable input impedance and gain are simply to die for.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
Are the handles on the back so that you can use it as a self-defense weapon? Yeouch! Amp to the head!Ludicrous gibs!
Rack handles, on the **** end.
You'll need both hands, trust me. Kind of a half 'clean and jerk' move, for you weight-lifting types.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
*drool*
*remembers last time he said that in FM he ended up with item*
*drools some more*George Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
