Denon 3801 3802
VinnyP61
VinnyP61 Posts: 28
edited April 2002 in Technical/Setup
Just got a real good deal on the Denon 3801 just wonder what differnce there is between 3801 and 3802 thanks.
Post edited by VinnyP61 on
  • mhetman
    mhetman Posts: 25
    edited April 2002
    5 watts/ channel more for the 3802 and Dolby Pro Logic II..
  • shack
    shack Posts: 11,154
    edited April 2002
    I have also heard that the 3801 ran quite hot at times and the problem was corrected with the 3802. I know several folks have bought a small Radio Shack fan and set it up so that when the receiver was turned on the fan came on and blows over the receiver to keep it cool. Here is a thread over at HTF that you might want to read. CLICK HERE
  • mantis
    mantis Posts: 17,056
    edited April 2002
    I won the 3801 and no heat problem's.I have installed hundered's of these receiver's and again, no problem's.If you can get a good deal on a 3801..go for it, the 3802 isn't worth the extra money.5 watts and pl2 is correct.thats it.
    Dan
    Dan
  • mhetman
    mhetman Posts: 25
    edited April 2002
    No heat problems here...Very happy with mine.
