RT35i and RT55i
emcrites
Anybody know the tweeters moniker in these speakers? SL-65XX? Blew a crossover in my RT35 and I guess I'll need to update them both to RT35i parts. Will tweeters from RT200p's work? They're SL-6506's. Thanks.
Post edited by emcrites on
Hi Emcrites.
Welcome to the forums.
You might want to post this question in the "Troubleshooting" thread- or you can click directly on the moderator of that thread and send them a PM in reference to your problem. Kenneth is really good.
Best,
Andrew H. -
The original tweeter is part number BD0125-W and has been replaced by part number RD6514-3 which is a soft dome tweeter. The tri-lams are no longer available from Polk."Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
You can't get the trilams as a factory replacement any more, like shack said.
If you have a trashed set, you might be able to swap them out as long as the bezel fits.
If you get the new replacement, you might want to get two. The new ones sound different than the older ones.
