SDA-1's
TnBilly
TnBilly Posts: 14
edited June 2005 in Vintage Speakers
I recently purchased on epay an original set of SDA-1's - the 82 vintage (1780 & 1781). With the exception of one tweeter cap that's been replaced they "appear" to be original and in working order. I've replaced the posts as the originals were a little beat and the plastic nuts gone. While doing that job I noticed the passives looked a little different than I was used to seeing, at least they're differenct than the ones on my SDA-2's. They're open in the back of the cone for one thing and they have a much more "styrofoam" appearance whereas my sda2's have a black covering over the small end of the "cone". Anyone else that has a set of these willing to compare notes with me? Thanks
Post edited by TnBilly on
  • nadams
    nadams Posts: 5,877
    edited June 2005
    Can you post pics of them, so we can see what you're talking about?
    Ludicrous gibs!
    F1nut Posts: 49,805
    edited June 2005
    Perfectly normal, they should be different as they are different models from different years.
  • TnBilly
    TnBilly Posts: 14
    edited June 2005
    Thanks guys....
    I did a little dissassemby on my sda2's and the sda1's in question. The passive on each looks for the most part the same, enough so I'm now reasonable sure the one in the "1" is stock. The only difference I can detect is the pad/cover on the front is a little thicker than the one on the "2". If I was to venture a guess I'd say that is at least in part how the resonant frequency is adjusted to compensate for the extra driver over the "2"s... wort part I found in all this is the sl1000' are now sl2000's and all the mw's are 6501's. The only thing thats says 1982 is the crossovers! I have the feeling they've had a rough life. One of the woofers made a metalic click when I pushed the passive and one of the mid's makes a little rubbing if you push it gently on one side only. If you push is squarely it seems to be okay. I'll look thru the archives and see what a good versus bad driver is supposed to be!
    Ron
    F1nut Posts: 49,805
    edited June 2005
    Bingo on the PR's.
    Look closer it the mid driver making the "click", probably a bad one. The mid drivers will make a scratching noise if pushed in on one side only, don't do it, push evenly.
  • ND13
    ND13 Posts: 7,601
    edited June 2005
    Originally posted by F1nut
    Bingo on the PR's.
    Yeah, and better yet, don't push on them at all once you're done exploring.;)
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • TnBilly
    TnBilly Posts: 14
    edited June 2005
    Thanks!
    I can state without reservation the driver with the "click" was bad.. all I had to replace it with was a 6510 I'd picked up as a spare but even so my "ears" now say the bass on the left is back where it belongs and the balance if you will is there. I'm much pleased with these over the 2A's even if they are kinda a kludge. I"m thinking it would be nice to go ahead and go thru the crossovers this winter and bring them up to the newer revisions using better parts.
  • hotwheelman
    hotwheelman Posts: 1,300
    edited June 2005
    Tnbilly.......where in east tn. are yoiu located?
    "Its worked so far but we're not out yet."
    "Hey big man let me hold a dollar"
  • TnBilly
    TnBilly Posts: 14
    edited June 2005
    Just outside Tellico Plains! Yourself?
  • hotwheelman
    edited June 2005
    Upper east end, Bristol. Dad did some work for sperry down there when I was just a bean sprout, been a while since I was down that way.......fishing excursions would bring he and I down that way as well.:D
  • TnBilly
    TnBilly Posts: 14
    edited June 2005
    Interesting...... these SDA-1's I just picked up afew weeks ago came from Kingsport. I was probably bidding against some of the guys here!
