Fuse For 5jrs
rebfan
rebfan Posts: 2
edited June 2005 in Vintage Speakers
I've got a pair of 5jrs with blown fuses. Does anyone know what type of fuse goes in the 5jrs?
Post edited by rebfan on
    F1nut Posts: 49,802
    edited June 2005
    Read the info on the fuse caps.
  • ND13
    ND13 Posts: 7,601
    edited June 2005
    I believe they use a 5 fast burn.
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • RuSsMaN
    RuSsMaN Posts: 17,987
    edited June 2005
    1 amp fast blow
  • ND13
    ND13 Posts: 7,601
    edited June 2005
    Originally posted by RuSsMaN
    1 amp fast blow
    See, there's your answer.
    BTW, what should the 10A's have?
  • rebfan
    rebfan Posts: 2
    edited June 2005
    The info on the fuses is unreadable. Where would I get these fuses?
  • ND13
    ND13 Posts: 7,601
    edited June 2005
    Rat Shack
  • ndrwcn
    ndrwcn Posts: 30
    edited June 2005
    i just picked up a pair of monitor 7's, and one of them is lacking both the fuse and the fuse holder. both are playing, with no apparent problems (all the drivers are firing, and sound great). do i need to do something, or can i go without a fuse? if i do need a fuse, how would i go about attaching a new holder?
    thanks,
    andrew
  • nadams
    nadams Posts: 5,877
    edited June 2005
    Not all old monitors have fuses. They eventually switched over to an internal circuit breaker-type design.
    Ludicrous gibs!
  • ndrwcn
    ndrwcn Posts: 30
    edited June 2005
    my pair of speakers appear to be an original matched pair, so i had assumed that the fuse assembly had been broken off of one of them. how do i check if the speaker i have should have the assembly, or has an internal setup like mentioned?
  • nadams
    nadams Posts: 5,877
    edited June 2005
    Well, without the fuse present (if it's truley broken off), you'll get no sound out of the tweeter on that speaker. That would be the easiest way to tell. Unless the previous owner somehow bypassed the fuse terminals and just has it straight wired.
    Ludicrous gibs!
