SDA Grills?
Roy Munson
How many of you that own SDA's listen to them with the grills off? Every time I listen to my 2a's with the grills off it seems like a veil is lifted and I much prefer the way they sound this way. Also does anyone have any experience with recovering their grills with a more acoustically transparent cloth? If so what did you use and are you happy with the result?
2 Channel:
Amp/Parasound Halo A23
Pre/Carver C-1
Tuner/Carver TX-11a
CDP/Jolida JD 100A
Turntable/AR XB-Shure V15 III
Pre/Carver C-1
Tuner/Carver TX-11a
CDP/Jolida JD 100A
Post edited by Roy Munson on
hmmm? i honestly don't hear much difference with the grilles on or off. maybe., my hearing isn't that good anymore..
PolkFest 2012, who's going>?
