Digital Out with AMR-130
blown302
I have a SBLive 5.1 on a kr7a-r, and I'm using the AMR-130 speakers, which I love BTW. But when I check the "digital output only" tab in the creative surround mixer, all I get is static. Anyone have any ideas?
Post edited by blown302 on
Nobody? Somebodies gotta know something about this combo.
Please! -
The digital out is used for if you are hooking up to a decoder, either Dolby Digital/ProLogic 1/2. Might be some speakers that can decode but they would probably brag that it has that support. You are using the analog signal which is straight audio, digital is compressed(zipped if you will) audio that needs to be decompressed before being heard. Your SBLive! 5.1 has a decoder in it(AC3=Dolby Digital) just in case you didn't know.
wend you set to digital out on your sb-live this is for malti- digital speakers that haves its own da converter buit in to the speakers, if you dont have the digital speackers you wont get no sound. rt-7 mains
rt-20p surounds
cs-400i front center
cs-350 ls rear center
2 energy take 5, efects
2- psw-650 , subs
1- 15" audiosource sub
lets all go to the next ces.
