sealed box for 2 2104's
silva95teg
silva95teg Posts: 13
edited June 2005 in Custom Fabrication
has anyone built a box for 2 2104's i want to make it sealed and not too big , what is a good volume overall. the subs say .66 cubic feet each , but i do not know if that is includeing them in the box as well
Post edited by silva95teg on
  • MacLeod
    MacLeod Posts: 14,358
    edited March 2005
    .66 is gross volume. That means the total box will be .66 before the subs are put in there.
  • silva95teg
    edited March 2005
    so has anyone made a box that size , just wondering if it should be a little bigger or if thats a good size, thanks
  • MacLeod
    edited March 2005
    Thats the recommended size for optimum performance. Recommended by POLK AUDIO that is, and I rekon they should know since they designed and built it. ;)
  • silva95teg
    edited March 2005
    alright if they know i will give er a try , i am sure it will still sound pretty good
  • Systems
    Systems Posts: 14,873
    edited June 2005
    He asked about 2 subs. Do you just make a box twice as big with a divider?
    thanks,
    Riooso
    Testing
    Testing
    Testing
  • silva95teg
    edited June 2005
    yes that is what you do just double the volume, but i did not use a divider and they sound great, nice and tight. They dont play lows that well but i am still happy.
