Polk Audio - Monitor Series - Stands - Reference
  • dorokusai
    dorokusai Posts: 25,576
    edited September 2010
    Yes, the actual angle is 6 degrees, the 4 degrees is a typo on my part and an early pair of stands. Great work Rev...post some pics.
  • SolidSqual
    SolidSqual Posts: 5,218
    Hey,
    I just picked up a pair of Monitor 10Bs with original stands. The stands are affixed to the base of the speaker with four screws. One of the stands is loose between the base of the stand and the metal plate affixed to the speaker with four screws. The screws are extremely tight and the space between the base of the stand and the speaker doesn't allow enough room to unscrew the screws without stripping them. IS there another way to tighten the base? Should I just glue the stand to the metal base?
    Thanks,
    Mike
  • wanders
    wanders Posts: 15
    edited July 2011
    dorokusai wrote: »
    Drawing.
    Could anyone describe how the center 10.5" x 4" tilted support box (column) is constructed?
  • wanders
    wanders Posts: 15
    edited July 2011
    dorokusai wrote: »
    Drawing.
    I'm going to be building some m-10 stands soon. In looking around, I found the following website that may be useful for calculating the tilt angle:
    http://blocklayer.mobi/riserun.aspx
    It's a run/rise/angle calculator. You imput two variable and it solves for the third. In the revised diagram provided by dorokusai, the total rise is 1" over a run of 8.75 inches making the angle 6.5 degrees. Cutting the rise down to 1/2" lowers the angle to 3.3 degrees. If you want to lower the angle from 6 degrees, you could mess around with the calculator to determine the exact measurements necessary to build the riser.
    As per my previous post; I'm a little unsure about constructing the riser. If it's made from mdf using screwed and glued butt joints, my gut says the box is a little weak to support fifty pounds, especially since all the screws would be set into the end grain of the mdf. I'm thinking the box would have to be significantly reinforced or should be made using solid wood, maybe clear doug fir, would be safer.
    Would appreciate any thoughts.
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited August 2014
    dorokusai wrote: »
    I'm not sure why the pics won't load up for you....lets try this.
    They always lock. I'll try and find out why.
    Good simple plans! Could be made with a hand saw if necessary. I made a pair simular very easy.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
    mhardy6647 Posts: 35,184
    someone - somewhere else - was looking for this info; good to see it (still) here.
    - I am posting ro it only with the intent of bringing it back up to the top of the stack;we'll see if that works.
