What are the grilles of SDA speakers made of?
trubluluc
trubluluc Posts: 2,067
edited December 2004 in Vintage Speakers
The grilles on the 1.2's don't look like they are made of wood.
-Luc
Post edited by trubluluc on
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    On my 2As, 2Bs, and SRSs they're made from a dense, but very light weight, resinous pressed material - almost has the appearance of fiberglass.
  • trubluluc
    ....I figured not wood, some type of plastic/fiberglass combo.
    Well I got mine a little wet, with a little too good of cleaning job.
    The fabric looks great, but the frame has warped a little on both of them.
    I may have to re-wet them and put them under some framing and weight to un-warp them.
    Anyone else suffer from
    over zealous cleaning syndrome ?(stupidity)
    Suggestions? (besides therapy)
    -Luc
    F1nut Posts: 49,711
    It seems to me that just the back side (facing the drivers) has the resinous coating, the actual frame appears to be pressed fiberboard. That kind of material expands like crazy when it gets wet, I'd be very careful about getting them too wet again, but the press 'till dry is a good idea.
  • BlueMDPicker
    Further research reveals they are made from recycled Bose cabinets.
  • mesquitehead
    mesquitehead Posts: 312
    micro density fiberboard....denser than particle board and great for cabinets as well.
    "Thats great... but how does it sound"
    http://www.burginmcdaniel.com/
    http://mixonline.com/gear/reviews/audio_burgin_mcdaniel_komit/
    Yamaha RX-A820 (networked with wireless bridge), Carver M-1.0t, Carver TFM-35, Carver C-1, Polk SDA1c's (x2 pair), Polk RTA 8tl's, Polk RTA 11tl's, Polk Monitor 5, Polk CS 400, Polk PSW 650, Rega Planar 3, Sony DVPNC555ES SACD/DVD, Panny 65" Plasma, Roku
    2007 Tundra 5.7 TRD DC
    Pioneer DEH-80PRS
    Polk SR6500
    SI BM 12" subs
    Zed Gladius
    Zed Deuce
