How far away do I have to place SDA's...
trubluluc
...from a rear projection TV to avoid having them distort the TV?
Looks like my RT3000's will be out of commission in the H.T. for a spell,
so I thought I might hook up the 1C's and give them a whirl.
-Thanks,
-Luc
-Thanks,
-Luc
Post edited by trubluluc on
Two or three feet. You can see if you are too close.
It shouldn't matter on an RPTV as much as it does on a tube TV. Shielding has little effect on the inner workings of what is basically a projector in a box.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
What are the signs of interference?
I have my SRS right up against my CRT RPTV, but have not noticed anything... -
If it were there, you'd notice it...
Purple, green distortions along the edge where the speaker is at... Darkening of the screen, etc..- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
....but the worst effect is when Sid's head pops up on your screen. There's no hope after that!Political Correctness'.........defined
President of Club Polk -
Oh, I'd say Georgia should be just about far enough:cool:
