custom boxes
Frontier
Frontier Posts: 4
edited October 2004 in Custom Fabrication
does any one have any tips for doing your own carpeting on things such as boxes and what not? any thing helps thanks.
Frontier
Post edited by Frontier on
  • neomagus00
    neomagus00 Posts: 3,899
    edited October 2004
    Crutchfield has some box-building advice. most notably, indent the sides of your box by 3/8" to 1/2" in order to be able to wrap the carpet over the edge and hide the seams in the corners. lookee here for what i'm talking about (this is my as-yet-uncarpeted dorm sub).
  • exalted512
    exalted512 Posts: 10,735
    edited October 2004
    use 3M adhesive spray
    -Cody
  • neomagus00
    edited October 2004
    and heavy duty staples (not the office kind) in the seams if the freakin thing just won't stay down. and don't put the carpet under where the sub'll mount, it should be screwed straight to the wood (if you're going to have anything in between, make it something useful, like weather stripping, which actually is a good idea).
