SDA 2 interconnect
donzidude
donzidude Posts: 4
edited October 2004 in Vintage Speakers
Looking for the cable for early SDA 2. Looks like 2 flat pin type. Also, would no cable cause the tweeters to not work?
Thanks,
Chris
Post edited by donzidude on
    F1nut Posts: 49,850
    edited October 2004
    Chris,
    Contact Ken at Polk, 800-377-7655 x 891. Polk has them in stock, cost about $35.00. Not using the cable will cause the SDA tweeter and the SDA mid driver not to work, but not both tweeters. You might want to check the fuse and/or the fuse/clip contact.
  • Tour2ma
    Tour2ma Posts: 10,177
    edited October 2004
    Welcome to the Club... dude....
    Are we talking original SDA 2 here with drivers recessed behind a frame? or the flat-faced 2's?
    Do you have pic capability?
    Not that pics are needed to help troubleshoot, F1's got you convered there.... but if they are the originals, they'd be the 1st of them I'd seen...
    More later,
    Tour...
    Vox Copuli
  • Tour2ma
    edited October 2004
    Chris,
    You can rig a SDA IC using speaker wire.
    Do you know about the common ground amp requirement? It is likely that yours is (most are), but tell us what you have.
    More later,
    Tour...
    Vox Copuli
  • donzidude
    donzidude Posts: 4
    edited October 2004
    I got these at a yard sale. They have 3 mid bass and 2 tweeters w/ pass. rad. each. The drivers are not recessed in the cabinet but are mounted on the face. 1 tweeter works on L spkr but none on right. I removed them and they test fine. Also, these have the fuse less overload protection.
    thanks for all the help so far!
    Chris
  • RuSsMaN
    RuSsMaN Posts: 17,987
    edited October 2004
    No SDA's have drivers recessed behind a frame.
    The early 'nudie shots' in magazines showed the GRILL frame attached, but with no grill cloth.
    Cheers,
    Russ
  • amulford
    amulford Posts: 5,020
    edited October 2004
    When you say they tested fine, how did you test them? Is it one or both tweeters? Have you checked out the crossovers or looked for continuity from the binding posts?
  • Tour2ma
    edited October 2004
    Cheers,
    Russ
    Fooled me... the 6 holes in the "frame" certainly looked like they were meant to receive grill posts...
    Must have been before Al came on board... eff'd up way to pose a speaker...
    More later,
    Tour...
    Vox Copuli
