WTB: pair of f/x300i speakers
craigmcraigm Posts: 8
edited September 2004 in Wanted (WTB) Classifieds
I'm looking for a pair of f/x300i surround speakers to match my rt55i fronts and cs400i center. Anyone know of a way to find some of these.
Post edited by craigm on
  • Meeks32Meeks32 Posts: 330
    They are on ebay quite often, I got my white ones a few months ago from there for $190. Also I dont think they are the exact match for your setup(I have that same setup also), I believe the 500's are the match since they have the same tweeter. I would have gotten those but couldnt find any.
  • craigmcraigm Posts: 8
    Your right the 500i probably is the better match, but they are to big for where I need to hang them. I'm sure the 300i would work just fine. I'll keep watching Ebay.
  • francis1967francis1967 Posts: 161
    FS fx/300i
  • Airplay355Airplay355 Posts: 4,150
    fx300i will work fine, they have the same tweeter as the 55i and 400i.
  • danger boydanger boy Posts: 15,888
    F/X300i have silk dome tweeters..
    55i's and CS400i have tri lams
    but as surrounds.. they match close enough. that you would be hard pressed to hear a difference.. i can't and i have tri lams in front.. and silk domes for surrounds.
    PolkFest 2012, who's going>?
  • okiepolkieokiepolkie Posts: 2,284
    I found this set on ebay tonight (no affil). Didn't know if you had seen them.
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=14996&item=5722726744&rd=1
    Tschüss
    Zach
Howdy, Stranger!
