WTB : Polk Passive Radiator Pair
RuSsMaN
RuSsMaN Posts: 17,987
edited September 2004 in Wanted (WTB) Classifieds
Anyone have an extra set of 12" or 15" pr's?
Cheers,
Russ
Post edited by RuSsMaN on
  • hotwheelman
    hotwheelman Posts: 1,300
    Russ, You only looking for those two sizes?
    "Its worked so far but we're not out yet."
    "Hey big man let me hold a dollar"
  • RuSsMaN
    Pretty much, I need to load a bit of mass on them. 10's might work.
  • hotwheelman
    Got two 10's out of a 15tl, you want em?
  • RuSsMaN
    Possibly, do you know if they came from the front, or rear on the 15?
  • hotwheelman
    One front, One rear, just had the one cab that these came from.
  • RuSsMaN
    Thanks for the offer, but I'll pass. The 15 had 2 different (weighted) pr's - one front and one rear, tuned to different freqs.
    I'm looking for a matched pair to start with, for a stereo sub project.
    Cheers,
    Russ
  • hotwheelman
    No prob., guess I should post this in another thread but how hard is it to calculate for a passive? Also I was looking at these the other day and the only difference in the rear passive from the front one is they added another puck. Could the one be removed without effin the passive up?
  • dorokusai
    dorokusai Posts: 25,576
    Most PR's are simple weighted, and easily adjusted. If it is the same model PR, then yes, add/remove is fine...for the application. I wouldn't drop or add weights just to experiment, as the work was already done for us....if it worked better, it would.
    If it is a different PR, then you have a curveball.
  • RuSsMaN
    Tell you what, I thought of another project they would be usefull to me in, bring them to the gathering, fair nuff?
    Cheers,
    Russ
  • hotwheelman
    Cheers,
    Russ
    Roger that.
