speaker box mm2124's
Systems
Systems Posts: 14,873
edited September 2004 in Custom Fabrication
im planning to build a bandpass box for two mm2124's and i want to follow the box plan here at polk but i dont understand the dimension that says "35-41/100" could someone please help?!?
Testing
Testing
Testing
  • neomagus00
    neomagus00 Posts: 3,899
    edited June 2004
    that's to be exact... get to within 1/8", namely 35 and 3/8 inches.
  • SlainNothing
    SlainNothing Posts: 3
    edited July 2004
    don't build a bandpass.
    go sealed. its easiest and a hell of a lot better.
    - Slain
  • LittleCar_w/12s
    LittleCar_w/12s Posts: 568
    edited July 2004
    Truly you know this from many other posts... POLK subs run better, cleaner, smoother, and LONGER in sealed boxed matched to them.
    -Jerry
    ___________________________
    Total cost of materials: Going up...
    Time spent: Countless Hours...
    Cranking the system, having it quiet outside the car, and sound that takes the rear-view off inside: PRICELESS
    For some things in life, you pay others to do it... For a masterpeice, do it yourself.
  • MacLeod
    MacLeod Posts: 14,358
    edited July 2004
    Yeah, let me throw my hat into the "pro sealed box" ring.
    Theyre easier to build, can handle more power, are more forgiving of build errors and sound tighter.
  • neomagus00
    edited July 2004
    as said, sealed is definately tighter, more reliable, and easier to build, as well as better for your speakers' longevity, but if you're set on the loud bandpass box, you picked the right momo sub to do it with...
  • cpmzx3
    cpmzx3 Posts: 9
    I am doing 2 2124's in a band pass today (3 chamber. polk's spec'd box). Going to break them in over 2 weeks with 150 watts each. I will let ya'll know what the eq., spl. turns out to be with 300w total.
    2k Focus ZX3
    Pioneer Premier DEH-P860MP
    2 Polk Audio MM2124's
    More to come...
  • neomagus00
    be more careful than you think you need to be on breaking them in, just in case
  • exalted512
    exalted512 Posts: 10,735
    what he said
    -Cody
  • cpmzx3
    cpmzx3 Posts: 9
    OMG! 141.5 on an Audio Control unit. (300 total watts)
    May not be W7 but that box plays notes that I only used to hear in systems that had 8 12's tuned LOW..
    IE ZZTop, Heads in Mississippi. Erich Kunzel, Planet Krypton
    Plays those UBER notes. :)
    The tonal range for application is great too...
    Nice and tight with the rumble for rock.
    Kick butt on the Rap
    Country romps
    With the little power I am pushing to them they are hardly moving..
    Cant wait till I put 800w to them....
    More to come...
  • neomagus00
    sweet... glad it turned out the way you wanted... as long as you've broken them in, rock on!
