Canare 4s8 speaker wire. Man cave cleanout!!
2x 35' lengths of Canare 4S8 speaker wire. Terminated with Via Blue OFC tubes. The tubes are soldered and crimped to the wire. Total of 70 feet of wire.
The ends I use with these have set screws, tubes go in the ends, set screws attach the end to the tube.
$30, you pay shipping.
Aaron
Enabler Extraordinaire
  • scubalab
    scubalab Posts: 3,105
    edited November 2018
    Sold! I’ll take them. PM incoming.
  • ALL212
    ALL212 Posts: 1,670
    crap...I didn't charge enough!! AGAIN!!!
    Thanks - I love the quick sales.
    Aaron
  • scubalab
    :D
    But shipping’s gonna be like $75, right? ;)
    These will replace the “slimy green oxidized speaker cables” I Karma’d a couple weeks ago.
  • ALL212
    ALL212 Posts: 1,670
    I was thinking more like $100 shipping... :*
    I can send my version of green oxidized cable with them if you'd like, no extra charge at all...except another $25 in shipping of course.
    Aaron
    gudnoyez Posts: 8,201
    Great Deal, what else you got stashed in the cave your wanting to part with?
    pitdogg2 Posts: 27,684
    Now that this deals been done time to crap...
    Canare is some darn good cable for the money. Once i found out signal ultra cable was 2 runs side by side of 4s6 and 2 of our northern Illinois polkies had sold me two different sets. I decided to go extreme I've used single runs of 4s11 on the kids gear I decided to go out and try two runs of it side by side. It makes IIRC a 9 gauge cable.
    Wow I could tell a massive difference between the Signal Ultra pair of 4s6 immediately. That is what I'm running now dual runs of Canare 4s11. I'd buy much better cable but my runs are 20' and well that is way too pricey for things with big brand names. Like Aaron i too found the via blue crimp tubes worthy they are marvelous and the just slide into most bananas and tighten down. I however did not also solder them like Aaron.
  • ALL212
    ALL212 Posts: 1,670
    I’ve been migrating to Mogami and Wireworld speaker cables. Don’t ask for a comparison as I haven’t a/b’d anything due to an extreme case of “damn, that sounds good so why change anything” itis.
    Main rig is using Groneberg cable for everything (including internal wire for pre and power amps). And that stuff ain’t goin’ anywhere!!
    Aaron
    I do like the wireworld stuff but the stuff I'm drawn to is way out of reach.
    I've heard a ton on that Groneberg cable all good.
  • ALL212
    ALL212 Posts: 1,670
    Sold and gone
    Aaron
    mhardy6647 Posts: 35,457
    Apropos of nothing -- something about @ALL212's current avatar makes me think of famous amateur radio operator (and occasional guitarist) Joe Walsh. :|
  • ALL212
    ALL212 Posts: 1,670
    Brother from another mother...
    Aaron
