McCormack DNA-125 Stereo Power Amp - No longer for sale
halo
halo Posts: 5,616
edited December 2018 in For Sale (FS) Classifieds
McCormack DNA-125 stereo power amplifier. This amp has been modded by Bob Backert of RHB Sound Dezign with upgraded signal path caps (Black Gate) and power supply. Cost of the mod was $500.00 alone. This is, bar none, the best sounding amp I have ever owned. The amp looks good except for a few blemishes here and there. Nothing big or really noticeable but I'm being overly cautious in my description just in case you see something I miss. Rear lettering has aged in a few places. The amp performs and sounds amazing. Original box & packing materials included. Local pick up is welcome and encouraged. I will ship at buyer's expense.
Price is $1000 to Polk Forum members in good standing with at least 100 posts. Price is $1200 to anyone else.
  • verb
    verb Posts: 10,176
    That is one sweet amp!
  • Nice amp..
    Living Room
    Parasound HINT 6, Yamaha Aventage RX-A 1060, Yamaha BD-S681, Cambridge Audio Azur 851N, Polk S60, Polk S30, Samsung 60" LED
    Office
    Cambridge Audio 851A, Auralic Aries Mini, LSiM 703s
    Douglas Connection ICs and Cables
    tonyb Posts: 32,903
    Almost 150 looks and no takers ? C'mon guys, for the price it doesn't get much better for an amp of this quality.
  • monepolk
    monepolk Posts: 1,140
    Bad timing for me. :'(
  • sucks2beme
    sucks2beme Posts: 5,557
    edited November 2018
    Got a Mccormack singing away while reading this.
    Hard to beat for this price
  • joecoulson
    joecoulson Posts: 4,943
    Bad timing here too
    Just picked up more power too
    tonyb Posts: 32,903
    la2vegas wrote: »
    tonyb wrote: »
    You're one of lookers big boy, batter up! :D
    If I was in a different situation, I'd be all over this. That and...if I had your money, I'd burn mine. :):)
  • halo
    halo Posts: 5,616
    Bump
  • hochpt21
    hochpt21 Posts: 5,423
    How would this compare to a DNA .5?
  • halo
    halo Posts: 5,616
    DNA 0.5 is older.
    Specs:
    Output Power: 100 watts per channel into 8 ohms, and 200 watts per channel into 4 ohms, both channels driven from 20 Hz to 20 kHz at less than 1% THD.
    Output Current: 25 Amps peak, per channel
    Input Impedance: 100 Kohm
    Input Sensitivity: .850 Vrms
    Voltage Gain: 30 dB
    Frequency Response: - 3dB @ .5 Hz, 200 kHz Signal-to-Noise: 100 dB
    Harmonic Distortion (1 KHz, 8 ohm load): .05% Signal Polarity ("Absolute Phase"): Non-Inverting Power Requirements: .65 Amps / 80 Watts @ Idle
    3.2 Amps/ 400 Watts @ Clipping (8 ohms) 117 VAC / 60 Hz
    Dimensions: 19" W x 5 7/8" H x 15" D Shipping Weight: 30 lbs
    DNA-125 is newer and this is modded by Bob Backert.
    Stock Specifications:
    Power: 125 watts per channel at less than 1.0% THD or IMD, both channels driven into 8 ohms from 20 Hz to 20 kHz. 200 watts per channel into 4 ohms.
    Input Impedance: 100 kOhms
    Input Sensitivity: 1 volt rms
    Hum and Noise: better than 98 dB below rated power
    Dimensions: 5.125" H x 16" D x 19" W
    Weight: 37 lbs.
  • stangman67
    stangman67 Posts: 2,179
    Damn I want this. Terrible timing though, I’m in the middle of moving, and will have to move again 6 months after this one, so the stereo is on the back burner for awhile. I’m sure you will be able to get rid of it pretty easily
  • halo
    halo Posts: 5,616
    stangman67 wrote: »
    I’d like to see it stay in the family here on the forum.
  • halo
    halo Posts: 5,616
    Bump
  • halo
    halo Posts: 5,616
    No longer for sale
