LSi25 crossover has damaged part.
sidnei100sidnei100 Posts: 10
edited November 1 in Customer Service
LSi25 crossover has damaged part. Polk's technical support couldn’t help me they say at the speakers is too old 😔
Best Answers
  • sidnei100sidnei100 Posts: 10
    Accepted Answer
  • F1nutF1nut Posts: 40,494
    Accepted Answer
    The one in the second picture is a 5 watt, 1.75 ohm resistor.
    Accepted Answer
    You should figure out why that resistor cooked before you replace it.
    I also noticed both lead ends on the board at D2 are green meaning the wire has oxidized. That issue needs to be addressed.
Answers
    There’s another picture with some numbers
    Lsi25
  • K_MK_M Posts: 1,035
    edited November 3
    Seeing oxidation on some of your driver leads, as mentioned above....
    Best bet, replace resistor with a 10 watt (or higher) of same value.
    Were the speakers played very loudly recently??
    Lsi15, Lsi9, LsiC,Rta11t,M5jr+,M4,SDA 3.1TL, SDA SRS 2.3TL, Rti6....Still listing stuff, a work in progress.
    B+W-
    Epos-
    Infinity-
    Advent-
  • pitdogg2pitdogg2 Posts: 11,113
    Polk no longer has any parts for the LSi25 to my knowledge. You have been giving excellent advice above
Howdy, Stranger!
